Failed to find a solution. Maximum number of Newton iterations reached. Returned solution is not converged.''
Posted 2017/01/13 11:38 GMT-5 Fluid & Heat, Computational Fluid Dynamics (CFD), Installation & License Management, Modeling Tools & Definitions, Parameters, Variables, & Functions, Studies & Solvers 2 Replies
I am trying to simulate Air flow through an extraction chamber. The file is too large to be attached here.. my inlet pressure is 1 pa and outlet is about -2 pa. It is the concept of suction which is being used.
I carried out the simulation first with fluid as water, density of 1000kg/m3 and Viscosity of 0.001 Pas with Laminar Flow as physics control.
But as my real case is with air, if i put fluid properties as density 1.24 and viscosity 0.0000195 (of air at 20C) keeping rest of the things same. My solution does not converge. Can someone please help me out, as
I get an error of "Failed to find a solution.
2 Replies Last Post 2017/01/18 4:19 GMT-5
