8 years ago
2017/01/25 2:47 JST
If I am understanding you correctly- you should look in the application library for "coil above plate." In that example you can perform a Global Evaluation (under Derived Values) using the expression mf.ZCoil_1 (1 being the coil number) found under Coil Parameters.
This gives you the complex coil impedance.
DW Greve
DWGreve Consulting
DW Greve
DWGreve Consulting
8 years ago
2017/01/25 19:19 JST
Thank you very much for your response, actually I already did what you said to me and I have got the impedance but when I look at the values I think that there is something wrong. may be I didn't set the poblem correctly.
1/Is there a difference in results if we use a circular multiturn coil or numeric multiturn coil?
2/ can I send you what I did to look at it when you have time?
Nirmal Paudel
Tribhuvan University/Electrical Engineering
8 years ago
2017/01/26 23:37 JST
Hi Bouhlal,
The following Application Example include a collection of different types of coils in 3D, which I think is very useful for understanding the difference in the result.
www.comsol.com/model/3d-coil-types-in-comsol-multiphysics-42431
Best Regards,
Nirmal
Hi Bouhlal,
https://www.comsol.com/model/3d-coil-types-in-comsol-multiphysics-42431
Best Regards,
Nirmal
