Import Java Packages in a method for App builder
I am performing data manipulation via a method in the app builder. My code requires additional Java packages to run. For example:
import java.io.IOException;
import java.util.List;
Has anyone successfully done this and run a class as a method?
1 Reply Last Post 2017/01/27 6:30 JST
Posted: 8 years ago 2017/01/27 6:30 JST
From Comsol Support:
If you choose File > Preferences and click on Methods, there is an option
to "View all code". Select that, and your methods will reveal a number of
import statements at the top. To import java.io.Console and the others, you
need just add the import statements that you listed.
From Comsol Support: If you choose File > Preferences and click on Methods, there is an option to "View all code". Select that, and your methods will reveal a number of import statements at the top. To import java.io.Console and the others, you need just add the import statements that you listed.
