how to write strain & strain rate in expression in comsol v 4.1
I am not able to write a expression for strain & strain rate in v 4.1.Actually, in v 3.4 strain & strain rate is wriiten as ux & uxt respectively.But same expression is not working in comsol v 4.1.pls help.
1 Reply Last Post 2011/01/27 17:52 JST
Posted: 1 decade ago 2011/01/27 17:52 JST
se previous thread, and turn on the preferences "equations" and check the new naming, its probably an upper case X you need, but this is physics dependent. Understanding the Frame issue is crucial in v4, if you want to be sure you know what you are doing ;)
Hi se previous thread, and turn on the preferences "equations" and check the new naming, its probably an upper case X you need, but this is physics dependent. Understanding the Frame issue is crucial in v4, if you want to be sure you know what you are doing ;) -- Good luck Ivar
