get certain elements of a mesh, then refine mesh there
Posted 2011/01/27 4:53 GMT-5 Interfacing, Mesh Version 3.5a 2 Replies
i'm quite new to Comsol and i'm not sure if the following is possible to do with the software combined with Matlab:
There is a simple 2D square geometry with a mesh on it.
Now i want to get a list of certain elements of that mesh: The list should contain all triangles that are located on a circle on that 2D plane defined by an equation like (x-1)^2+(y-1)^2=0.5.
Then i need to refine the mesh around the mesh elements on the list.
I thought it might be possible to determine the triangles by checking if a triangle has nodes that are inside AND outside of the circle (or if one or two nodes exactly on it). This could be done by inserting the coordinates in (x-1)^2+(y-1)^2<=0.5 and checking it the equation holds. The problem is that i don't know how to start or if this approach is possible at all.
Thanks for any suggestions :)
2 Replies Last Post 2011/01/29 5:11 GMT-5
