Comsol asking for Ratio of Specific Heats for solid.
I am trying to build a simple model that finds the temperature as a function of time.
The model is part gas / part solid I therefore used the Heat Trasnfer in Fluids physics and I defined the gas and solid parts.
When assigning material properties I use the materials defined in the database but it asks me to fill in the Ratio of Specific Heats for all materials (solid and gases).
According to en.wikipedia.org/wiki/Heat_capacity_ratio this is possible for gases but not for solids.
Am i doing something wrong or is it my understanding of the physics that are wrong ?
Thanks in advance for any help,
I've attached the model I'm working on.
4 Replies Last Post 2017/03/12 20:29 JST
Posted: 8 years ago 2017/02/04 0:57 JST
Hey Anthony,
I`m still getting used with Comsol, but from my experience, this can happen if you define your physics wrong and you set up a study intended for a gas to a solid.. which could explain why Comsol is asking for the ratio of specific heats. Someone more experienced should confirm this though.
Hey Anthony, I`m still getting used with Comsol, but from my experience, this can happen if you define your physics wrong and you set up a study intended for a gas to a solid.. which could explain why Comsol is asking for the ratio of specific heats. Someone more experienced should confirm this though.
Posted: 8 years ago 2017/03/11 16:53 JST
Did you find this solution? I also met this problem. If you found this solution, please you kindly let me know.
Thank you,
Theary
Hi Did you find this solution? I also met this problem. If you found this solution, please you kindly let me know. Thank you, Theary
Posted: 8 years ago 2017/03/11 19:37 JST
For solids the ratio is 1.
For gases: Cp - Cv = R
Hence: Cv/Cp = 1 - R/Cp
Ideal gas law applies surprisingly well even at elevated temperatures and pressures.
Lasse
For solids the ratio is 1. For gases: Cp - Cv = R Hence: Cv/Cp = 1 - R/Cp Ideal gas law applies surprisingly well even at elevated temperatures and pressures. Lasse
Posted: 8 years ago 2017/03/12 20:29 JST
Thank you, Lasse Murtomäki for your replying.
