9 years ago
2017/02/08 2:40 JST
If you are using convective heat flux.. and changing ambient temperature. then you can use ambient temperature as a step function or else type this expression in ambient temperature field . if(t<heatingtime, T_hot, T_cold).
8 years ago
2017/02/09 12:50 JST
Thank you for your quick reply.
In the model, I am applying a heat source which is moving with certain velocity and heating the specimen, when i am defining the time study the heat source is running for the defined time and by that time only heating is happening which i don't want. I want to stop the heat source functioning after certain time to diffuse the heat. for this i have to define heating time and cooling time in same simulation.
Henrik Sönnerlind
COMSOL Employee
8 years ago
2017/02/09 16:40 JST
Maybe this blog post will give you some ideas:
https://www.comsol.se/blogs/how-to-make-boundary-conditions-conditional-in-your-simulation/
Henrik
8 years ago
2017/02/09 18:39 JST
Thank you for your response.
Sujit
Sujit
