2011/01/28 22:22 JST
Could itbe that you are in structural and that v and vt are already used by COMSOL ?
Always use "private names, most 1-2 letter names are already used by COMSOL, sometimes you want to redefine them, but often it gives errors, as you need to know exactly what you are doing
2011/01/28 22:26 JST
Thanks a lot for you reply.
I'm not using Structural. I have chosen ODEs and DAEs.
I have attached the Model.
I'd appreciate it if you could take a look.
2011/01/30 3:04 JST
you cannot try to solve for an ODE alone as you have not defined any dependent variables What is v ?, and vol1 ?
You need to define some physics via an PDE and possibly add an ODE if required
2011/02/09 0:25 JST
Ivar is right (of course!).
But you can in fact solve an ODE, as a global space independent problem. You to define the dependent variable, as Ivar points out, and you can do this by setting Name to v in the Global Equations settings, also, change vol1 to 0 or something else that is defined.
If you want to solve a distributed ODE on a 2D domain (where sources may change with position, but you have no gradient driven transport), use rather a General form PDE and only use the f and da terms.
Niklas
Niklas
