How to cite the principal stress and the principal direction in model?
Dear all,
I want to cite the principal stress and principle direction in my permeability model for a porous media. But I cannot find such variables in the equation view. So how can i cite these two variables in my model?
Thank you for your help and time
2 Replies Last Post 2017/02/28 0:43 GMT-5
Posted: 8 years ago 2017/02/27 1:51 GMT-5
If you add a principal stress plot, you will see the names of the principal stress variables. The orientations have names like 'solid.sp1x'. ('1' for first principal stress, 'x' for x component).
These variables are not visible in Equation View since they are not computed by an explicit expression, but by solving an eigenvalue problem.
Henrik
Hi, If you add a principal stress plot, you will see the names of the principal stress variables. The orientations have names like 'solid.sp1x'. ('1' for first principal stress, 'x' for x component). These variables are not visible in Equation View since they are not computed by an explicit expression, but by solving an eigenvalue problem. Regards, Henrik
Posted: 8 years ago 2017/02/28 0:43 GMT-5
hi
I have some question about principal stress.
if principal stress has negative value, and orientation has negative value such solid.sp1=-1 and solid.sp1x=-0.5
in this case, i want to calculate the principal stress of x component.
if I just multiply two variable, the value is 0.5.
is this value mean correct value of principal stress of x component?
hi I have some question about principal stress. if principal stress has negative value, and orientation has negative value such solid.sp1=-1 and solid.sp1x=-0.5 in this case, i want to calculate the principal stress of x component. if I just multiply two variable, the value is 0.5. is this value mean correct value of principal stress of x component?
