Electric circuit with piezo sensor
Good Day,
I'm doing a design on comsol software, my project consists on connecting the output of piezoelectric sensor to an electric resistor. The disgn and simulation of the sensor has been done, now I want to connect the output of this sensor with an electric resistor. I would be gratful if you could advise if is't possible to do that or not? if so, how could I do this. Thank you
Best regards
1 Reply Last Post 2011/02/04 22:13 JST
Posted: 1 decade ago 2011/02/04 22:13 JST
if it is a "lumped item" you could try to connect up a SPICE model (see the doc) or if its a "physical FEM model, you must define it and then link the two with corresponding variables/equations
Hi if it is a "lumped item" you could try to connect up a SPICE model (see the doc) or if its a "physical FEM model, you must define it and then link the two with corresponding variables/equations -- Good luck Ivar
