Nagi Elabbasi
Facebook Reality Labs
8 years ago
2017/03/17 3:35 JST
Hi Javier,
You make the material nearly incompressible by selecting a high bulk modulus. For a Yeoh model the initial uniaxial modulus is 6*c1 which in your case is 1e5. So if you select a bulk modulus roughly 2 orders of magnitude higher then it’s nearly incompressible. However, for your case, I would make it even higher since your Yeoh parameters define a material that stiffens significantly with deformation (because of the high c3 value). So I would use a bulk modulus of at least 1e8.
Nagi Elabbasi
Veryst Engineering
Hi Javier,
Nagi Elabbasi
Veryst Engineering
Nagi Elabbasi
8 years ago
2017/03/17 3:36 JST
Here are figures showing the stress-strain behavior up to 10% logarithmic/true strain and up to 50% logarithmic/true strain.
8 years ago
2017/04/03 19:03 JST
Thank you so much for your answer. I will try your suggestion.
Best wishes
Best wishes
8 years ago
2017/04/11 23:51 JST
Hello again
I have a new problem... I am doing a new 2D-axisymmetric model with two different domains. The first layer has the parameters I wrote before in my first post. How can I simulate incompressibility conditions (value of the initial bulk modulus) in the second layer if the parameters of this new layer are:
c1 = 32682 Pa
c2 = -295847 Pa
c3 = 1138050 Pa
It's very easy to solve this problem in ABAQUS for example, but not here in COMSOL...
Thank you in advance.
Javier
Hello again
c1 = 32682 Pa
c2 = -295847 Pa
c3 = 1138050 Pa
Javier
