2011/02/17 7:42 JST
You can plot on the same final graphs results (under the same plot group) from two different studies, for which you have changed manually, as you propose too, the BCs.
I have heard that in a future version the BC enable/disable will eventually be linked to the studies such that you will automatically switch BC by selecting another study.
You then refer the sub nodes of your plot group to each separate solution, and the main Plot node to "none".
But this does not allow (from my knowledge) to do mathematical operations on data from the different solutions: I do not know about an operator combination of the type (or is it the "with()" and "at()" that could do ?)
solution(1,the_wanted_variable) - solution(2,the_wanted_variable)
Could be nice to have though
Perhaps if you make two identical but separate models, then you have unique names for each study, but then you cannot select 2 studies, nor combine two, from my knowledge, for Plotting
Remains Matlab where you can combine things at will
2011/04/17 20:45 JST
HI, Ivar,
I'm happy to find such a thread, because i want to combine many Separated solutions in different files generated by parametric sweeping. The whole transient simulation is about a moving Heat transfer, and each parametric solution contains a moving step. After the calculation, i have to plot a Temperature-time line at a specific point, so how to combine all the solutions together? Could you please give some suggestions or how to operate in matlab?
I have tried turn on the "store solution in model " option in parametric solver setting, but finally the solver failed as the storage consuming up RAM. (Even all solution can be stored in one model, they are stored separated in solution containers, which will cause trouble to post-process )
Thanks for your time,Dr.Ivar
Best regards
[QUOTE]
[/QUOTE]
HI, Ivar,
Best regards
2011/04/17 21:22 JST
I must admit that I have not now had so many data sets that I couldnt store everything in one file, even if some are up in the Gb size. If you have managed to distribute the solution among several files (I know how to do that in 3.5, not sure how to in v4) then I agree you have, from my knowledge, onlya Matlab (or perhaps also java programming) to revisit all these files and postreat yourdata, by combining content from the different files.
Perhaps new possibilities will come in V4.2, that is supposed to be "just around the corner" ;)
2011/04/17 22:57 JST
Hi,Dr.Ivar
Thanks for your prompt reply.
Could you please insight me how you make it in comsol 3.5 using matlab? Should I make a loop to visit every file (about 60 solutions) and then get the data with comsol script?
Because every step the mesh changes, I think it will be a tough job for me.
Till now, i don't know whether ALE can make it.
Best regards
Hi,Dr.Ivar
Best regards
