Error "complex-valued stress function"
Posted 2011/02/16 21:43 GMT-5 Studies & Solvers, Structural Mechanics Version 3.5a 6 Replies
I have already acquired results about the transient temperature distribution of a steel plate processed in the high frequency induction heating. When solid mechanics application was added to analyse the Thermal Elastoplastic deformation of the plate, an error read "complex-valued stress function" was warned.
Need help, Many thanks!
well I haven't seen that one ;) but if you analyse the sentence you should look at the way you define the stress, could it be that you are entering a complex value when a only real was expected, i.e. you are missing an abs() (+ sign) or a real() or perhaps even an imag() for a variable transfer ?
What are the values of this complex value ? is the complex part negligible ? ...
From thereon you should be able to decide how to continue
"Evaluation of post processing expression failed. Complex stress function".
The details on my model follow..
Model:
Axial Symmetry (2D) -> Structural Mechanics Module -> Static Analysis Elasto-Plastic Material model
Constants:
Th=1900+273
Tl=298
Rm=200e-6
Ra=2e-2
ht=1e-2
Em=314.5e9
sy0=414e6
Etm=68.9e9
Scalar Expressions:
currT=Tl+(Th-Tl)*(param*(param<=1)+(2-param)*(param>1))
Draw:
Rectangle 1:
corner at origin; width=Rm, height=ht/2
Rectangle 2:
corner at origin; width=Ra, height=ht/2
Subdomain Settings:
(1 - Inner Material):
elastoplastic material
E=Em
nu=0.380
alpha=5.35e-6
rho=10220
Hardening model: isotropic
yield fn: von Mises
sigma_ys=sy0
E_T_iso=Etm
(2- Main material):
isotropic
E=315e9
nu=.239
alpha=7.8e-6
rho=3690
(1&2):
Load->Include thermal expansion is checked
Tempref=Tl
Temp=currT
Boundary Settings:
(2&5 - 'bottom') Rz=0 (symmetry)
Mesh:
Initialized then refined twice (~8000 elements)
Solve:
Static elastoplastic -> Parametric Nonlinear
param = 0:0.01:2
(ramps temperature from room Temp to 1900°C then back down to room temperature).
Nothing else was changed from the default settings.
The following simpler model receives the same "Complex stress function" error
Draw a 1x1 square
subdomain:
Use the default material, select elasto-plastic, keep default elastoplastic settings (isostatic w/ tangent modulus).
check "include thermal expansion."
Tempref=298
Temp=298+1000*param
no boundary conditions imposed
solver: static elastoplastic -> nonlinear parameter
param=0:0.2:1
mises_axi=sqrt(sx^2+sy^2-sx*sy-sy*sz-sx*sz+3*sxy^2+3*syz^2+3*sxz^2+4*Sys^2*eps)
tresca_axi=max(max(abs(s1-s2),abs(s2-s3)),abs(s1-s3))
Nagi Elabbasi
Veryst Engineering
Your equation for mises_axi is missing an sz^2 term. That’s why it get negative values.
Nagi Elabbasi
Veryst Engineering
I apparently forgot it when typing it up above. The mises_axi is a preset variable (so I didn't actually define it within comsol..I was just manually copying it into the forum post from a copy from comsol's variable definition dialog box).
Suggested Content
- BLOG Losses in Three-Phase Transmission Lines
- FORUM Multi-valued results at nodes?
- KNOWLEDGE BASE Undefined Function Call
- KNOWLEDGE BASE Modeling of Step Transitions
- BLOG How to Model Different Types of Damping in COMSOL Multiphysics®
