1D heat model question, time dependent
Posted 2017/06/04 22:13 GMT-4 1 Reply
                                                    Hi, I'm trying to model heat loss between different material. I can find the heat flux at the given point given the time, however when i integrate the heat flux with respect to time to figure out how much heat is lost at a given area [J/m^2] I get a large negative number after 0.1 second. The point that this happens is where 2 materials touch (I'm assuming that they're touching perfectly right now). I've noticed that the point becomes near the average of the temperature of the two materials, however I want to assume that the temperature at this point is the same as the first material and that any equation to smooth out the transition between materials occurs in the second material so that there is heat loss at this point. I've tried setting the temperature of the point to the static state temperature, however that is not good enough.
1 Reply Last Post 2017/06/05 23:46 GMT-4
