Thermal stress with contact pairs
Posted 2017/06/09 7:25 JST 2 Replies
I'm having trouble with a simple thermal stress model (axisymmetric, time-dependent, COMSOL 5.1). The model has two cylindrical parts that contact each other on one face, starting at different temperatures. As heat flows between them, one will expand as it heats up and the other will contract as it cools. Since the contacting surfaces must be allowed to slide against one another as this happens, I am using Form Assembly with a Contact Pair at the interface. To model the heat transfer across the boundary, I am using a Pair Thermal Contact node in the Heat Transfer in Solids module. When I try to solve, I encounter the following error:
- Feature: Time-Dependent Solver 1 (sol1/t1)
If I change from Form Assembly to Form Union and disable the Pair Thermal Contact, the model solves just fine, so the problem seems to be related to the presence of the contact pair. Has anyone encountered this type of issue? (I'd upload the model but the uploader is telling me that the .mph extension is not allowed.)
Thanks!
Phil
Thanks!
Phil
2 Replies Last Post 2017/11/23 20:18 JST
