Add single parameter value to existing parameter sweep
Dear all,
I have been using the parameter sweep function to solve a time-dependent problem for different Reynolds numbers, let's say 500, 1000, 1500 and 2000. After investigating the result, I discover I would have wanted to include the parameter value 750. How can I add this single parameter value to the parametric sweep solutions without having to recompute all parameter values?
I have tried solving the single parameter value seperately and then using 'join' under data sets, but this does achieve what I want. Eventually I want to be able to export an animation of the problem, where the different parameter value animations are shown after each other in a single movie-file. For this I need the new parameter value to be in the same solution 'structure' as the parametric sweep solutions.
Thanks already!
0 Replies Last Post 2017/06/16 1:32 JST
Hello Robin Egberts
