What does qwf_u command mean?
What does qwf_u command mean? I want to calculate the convection heat transfer coefficient h. After that, the number of Nusselt.
Thanks for helping me.
5 Replies Last Post 2017/07/14 22:01 JST
Jeff Hiller COMSOL Employee
Posted: 8 years ago 2017/07/11 21:08 JST
If a string is present in your model, you can find it and its meaning using Ctrl+F, see www.comsol.com/community/forums/general/thread/133412 .
Hello, If a string is present in your model, you can find it and its meaning using Ctrl+F, see https://www.comsol.com/community/forums/general/thread/133412 . Best, Jeff
Posted: 8 years ago 2017/07/12 6:45 JST
And how about qwf_u command?
Hi, And how about qwf_u command? Thanks
Posted: 8 years ago 2017/07/13 3:35 JST
What about checking the CFD documentation (p231 v5.3) "wall function heat flux" the _u probably stand for the u component, check it out in the Equation View with the hint of Jeff.
When I have a doubt I run an index search on the COMSOL pdf docs, therein you find everything, but there are so many formulas and variables ;) For the rest the Equation view gives you the complements
Hi What about checking the CFD documentation (p231 v5.3) "wall function heat flux" the _u probably stand for the u component, check it out in the Equation View with the hint of Jeff. When I have a doubt I run an index search on the COMSOL pdf docs, therein you find everything, but there are so many formulas and variables ;) For the rest the Equation view gives you the complements -- Good luck Ivar
Posted: 8 years ago 2017/07/14 21:44 JST
Updated: 8 years ago 2017/07/14 21:47 JST
if you do not want to help, I beg you not to respond. I already looked but I still did not understand. I do not have experience with the computational package.
A hug.
Hi, if you do not want to help, I beg you not to respond. I already looked but I still did not understand. I do not have experience with the computational package. A hug. [QUOTE] Hi What about checking the CFD documentation (p231 v5.3) "wall function heat flux" the _u probably stand for the u component, check it out in the Equation View with the hint of Jeff. When I have a doubt I run an index search on the COMSOL pdf docs, therein you find everything, but there are so many formulas and variables ;) For the rest the Equation view gives you the complements -- Good luck Ivar [/QUOTE]
Posted: 8 years ago 2017/07/14 22:01 JST
Good morning,
I already did it but I still have doubts.
Grateful.
Good morning, I already did it but I still have doubts. Grateful. [QUOTE] Hello, If a string is present in your model, you can find it and its meaning using Ctrl+F, see https://www.comsol.com/community/forums/general/thread/133412 . Best, Jeff [/QUOTE]
