Plot Temperature wrt Extra Dimension in Thin Layer of Heat Transfer module
Dear all:
Thank you for clicking into this question.
I have a very simple structure for heat transfer analysis:
A very thin film (10nm) on a substrate (1mm).
The following is the domain/boundary name and the heat transfer gadget I apply
Block 1 (Heat Source)
Block 2
Block 3
--------Boundary 1 (Thin Layer)-----------
I would like to get the "Temperature" across the "thin layer", i.e., the T drop across the thin thickness.
The documentation said I should create a "Study 1/Solution 1 (2)" to accommodate the component "Extra dimension from thin layer"
Then use "1D plot group" with "Line graph" to plot it.
However, when I set the "y-Axis Data" as "comp7.ht5.tl1.Txdim"
and "x-Axis Data" as "nz normal vector"
and plot
the error message comes out and said
Undefined variable.
- Variable: comp7.ht5.tl1.Txdim
- Geometry: ht5_tl1_xdim1_xdim
- Domain: 1
- Expression: comp7.ht5.tl1.Txdim
- Plot: lngr1 (Line graph)
Is there any suggestion on this situation.
Thank you very much for your patience in reading and answering.
6 Replies Last Post 2017/07/14 11:55 GMT-4
Posted: 8 years ago 2017/07/13 14:14 GMT-4
Some keywords:
5.2a
Heat Transfer
Extra Dimension
Thin Layer
Thank you everyone!
Some keywords: 5.2a Heat Transfer Extra Dimension Thin Layer Thank you everyone!
Daniel Smith COMSOL Employee
Posted: 8 years ago 2017/07/14 8:57 GMT-4
Hi Christina, this is a little bit tricky, because you need to let the software know at which point in physical space you want to plot the temperature in the layers. You need to use the "atxd" operator to do this.
So, say the layer boundary condition is applied on the plane at z=0. The correct syntax to plot the temperature distribution would be:
atxd2(0.5[mm],0.5[mm],0,ht.tl1.Txdim)
This will evaluate the temperature in the layers at the point x=0.5[mm], y=0.5[mm], z=0 on the surface. You can refer to the attached model (which is created in V5.3).
Dan
Hi Christina, this is a little bit tricky, because you need to let the software know at which point in physical space you want to plot the temperature in the layers. You need to use the "atxd" operator to do this. So, say the layer boundary condition is applied on the plane at z=0. The correct syntax to plot the temperature distribution would be: atxd2(0.5[mm],0.5[mm],0,ht.tl1.Txdim) This will evaluate the temperature in the layers at the point x=0.5[mm], y=0.5[mm], z=0 on the surface. You can refer to the attached model (which is created in V5.3). Dan
Posted: 8 years ago 2017/07/14 10:31 GMT-4
Good morning,
I saw that there are two layers, each one with 5 microns. How to measure the temperature for z = 0, and for z = 10 microns, at x = 0.5 mm, and y = 0.5 mm? I also study this type of problem and I would like to know the thermal influence of coatings on cutting tools.
I appreciate the help.
Rogerio.
Dan
Good morning, I saw that there are two layers, each one with 5 microns. How to measure the temperature for z = 0, and for z = 10 microns, at x = 0.5 mm, and y = 0.5 mm? I also study this type of problem and I would like to know the thermal influence of coatings on cutting tools. I appreciate the help. Rogerio. [QUOTE] Hi Christina, this is a little bit tricky, because you need to let the software know at which point in physical space you want to plot the temperature in the layers. You need to use the "atxd" operator to do this. So, say the layer boundary condition is applied on the plane at z=0. The correct syntax to plot the temperature distribution would be: atxd2(0.5[mm],0.5[mm],0,ht.tl1.Txdim) This will evaluate the temperature in the layers at the point x=0.5[mm], y=0.5[mm], z=0 on the surface. You can refer to the attached model (which is created in V5.3). Dan [/QUOTE]
Posted: 8 years ago 2017/07/14 11:08 GMT-4
Hi Rogerio, you can use the Point Evaluation feature. See the Point Evaluation 1 feature in the attached model.
Dan
Hi Rogerio, you can use the Point Evaluation feature. See the Point Evaluation 1 feature in the attached model. Dan
Posted: 8 years ago 2017/07/14 11:25 GMT-4
Thanks.
Dan
Thanks. [QUOTE] Hi Rogerio, you can use the Point Evaluation feature. See the Point Evaluation 1 feature in the attached model. Dan [/QUOTE]
Posted: 8 years ago 2017/07/14 11:55 GMT-4
Hi, how this command (atxd2(0.5[mm],0.5[mm],0,ht.tl1.Txdim)) can pick up the temperatures in two points?
Rogerio
Hi, how this command (atxd2(0.5[mm],0.5[mm],0,ht.tl1.Txdim)) can pick up the temperatures in two points? Rogerio
