Ill-conditioned preconditioner. Increase factor in error estimate to 18704635135.61623
Hello
when i run my model, it gives me the solution, however i receive a warning too:
"Ill-conditioned preconditioner. Increase factor in error estimate to 18704635135.61623"
i would be grateful if anybody explain what it means.
Behrooz
6 Replies Last Post 2014/09/23 17:18 JST
Hello Behrooz Rezaeealam
Posted: 1 decade ago 2011/06/01 2:59 JST
I'm also interested if any one has advice on this particular Warning
TT
I'm also interested if any one has advice on this particular Warning TT
Posted: 1 decade ago 2011/10/17 21:56 JST
I also get such an error . In fact I am following a comsol example. In my case it is backstep laminar flow. It is strange. The results are exactly like what is expected as are shown in pdf model in the liberary but I get this error messege as well. Did you figure it out where it comes from?
Yours,
Marjan
Hi, I also get such an error . In fact I am following a comsol example. In my case it is backstep laminar flow. It is strange. The results are exactly like what is expected as are shown in pdf model in the liberary but I get this error messege as well. Did you figure it out where it comes from? Yours, Marjan
Posted: 1 decade ago 2011/11/08 1:32 JST
Nobody has answer for this question?. I also got same error when solving laminar flow in a tube!.
Posted: 1 decade ago 2011/11/08 1:35 JST
It may due to the scaling of your variables, cehck the results and see whether imposing a Manual scaling value similar to the results you still get the error message.
Cheers
Hi, It may due to the scaling of your variables, cehck the results and see whether imposing a Manual scaling value similar to the results you still get the error message. Cheers
Posted: 1 decade ago 2011/11/08 2:37 JST
Hi Amir,
Thanks for your reply. I get around that issue by changing the initial condition (instead of default value 0) to inlet velocity.
Hi Amir, Thanks for your reply. I get around that issue by changing the initial condition (instead of default value 0) to inlet velocity.
Posted: 1 decade ago 2014/09/23 17:18 JST
Hey,
I'm new to comsol and I get the same warning. Please point out how you fixed this problem! Thanks in advance!
Ivelin
Hey, I'm new to comsol and I get the same warning. Please point out how you fixed this problem! Thanks in advance! Regards, Ivelin
