8 years ago
2017/07/20 17:48 JST
Hi Alexis,
let's put in some formal terms:
Let
A : area of the rectangle
N: number of turns
g : gauge ie cross section of the conductor
First the area A is not only filled with conductor but also there is some
insulation. We can define a conductor fill factor as
cff = N*g/A
For something reasonable this value must be smaller that 1 (say 0.6).
To my knowledge it is not check be Comsol and it is up to the user to enter
reasonable values. In my opinion the behaviour of Comsol is ok (and you
may have a different point of view).
Indeed these values do not really enter the finite element computation and
are only for convenience of input and output.
If you prescribe a current I, Comsol will apply an external current density
N*I/A on the entire rectangle. Only for computing the Ohmic resistance
(which is an analytic formula and no finite elements involved) the wire cross
section is needed.
I advise you to read the respective chapter in the manual. Multiturn coils
are a bit more complex that it may seem. For example they assume the all wires
are equally distributed over the area, and don't care about the number of layers.
Regards
Jens
Hi Alexis,
Let
N: number of turns
cff = N*g/A
section is needed.
Regards
Jens
8 years ago
2017/07/20 20:57 JST
Hi Jens,
Thank you very much for your reply !
I think I better understand how Comsol manage its multi turn coil.
Let's say that I want to modelize the "real" coil which the cross section is on the left side of this picture :
gofile.me/2NLgz/J7BvFojds . (blue is insulating material and yellow conducting)
What is best :
-Use a rectangle geometry with a W width and a L length.
-Use a rectangle with the "equivalent conducting aera" of my coil (8*S1 here) keeping the same W/L ratio for the rectangle.
Since comsol will define the current density on the entire rectangle the second approch seems more appropriate for me.
Thanks again.
Hi Jens,
Let's say that I want to modelize the "real" coil which the cross section is on the left side of this picture : http://gofile.me/2NLgz/J7BvFojds . (blue is insulating material and yellow conducting)
What is best :
Thanks again.
8 years ago
2017/07/24 16:14 JST
I would use the option:
With just eight turns you might consider using the single turn feature.
Is this a transient or frequency study? Note that the multi-turn approach
is only valid if the skin depth is larger than the dimensions of the wire.
Regards
Jens
Regards
Jens
8 years ago
2017/12/19 11:19 JST
I am currently workin on a 3-D comsol 5.3a in AC/DC to generate the quasistatic magnetic field of order 65kA/m with frequency of 0.01Hz by the use of multiturn coil in which input is current but that thus not generate the required magnetic field. So can anyone suggesrt any method to generate the magnetic field.
