Hello Melanie Brondel
                                2012/01/19 19:21 GMT-5
                                                    Hi. I also am wondering about this. I know have COMSOL 4.2a. Does anyone know? Thanks
                                2012/01/19 20:20 GMT-5
                                                    if i am not mistaken, sldprt is belong to solidwork type format. You need to have solidwork and comsol interface module to import the file into comsol. double check it.
                                2012/01/19 20:25 GMT-5
                                                    Yes, I believe your right. I just did a little more digging, and found in the help file that solidworks and autocad files are supported in windows only. In order to get it to work on a mac, you need to export your part as either a .igs or a .step file
                                2012/02/25 14:14 GMT-5
                                                    You must save as *.x_t format in SolidWorks.
                                2012/02/26 2:56 GMT-5
I do not believe you MUST have a Parasolid file forat, but it's even more reliable than the STEP ones.
From my understandig  the way it goes:
*.SLPRT files are SW native format, but based on the PARASOLID CAD kernel, that by default uses *.X_T or *.X_B format, so these are very close. STEP, IGES etc are "standard" non vendor formats that do not have all functionalities of the specific CAD Kernel ones, IGES is far better for 2D than 3D for which I prefer STEP if no other are available. DXF is a AUTOCAD format that has become an more or less open standrd, but its mainly for 2D and many cases the "polyline" feature is not well implemented, the lines do not connect correctly, which leads to many errors and frustrations
You need the CAD interface to read the .x_t from my remebering, and the LiveLink to Solid works to read in the .slprt format. As I have both, I never remeber how it is exactly, so check carefully with your rep, and thereisa matrix somewhere on file format on the main web site of COMSOL.
Anyhow SW does only run on Windows, so te true Livelink, with variable exchange does only work with Windows for SW
