Dependant variable
Hello ,
How could I define a dependant variable in comsol a specific quantity like Displacment or displacment e.g suppose we have dependent variable u(x,y,t) and I want this dependant variable to be displacment.
Thank you
4 Replies Last Post 2011/03/10 19:41 JST
Posted: 1 decade ago 2011/03/10 18:08 JST
your question is not easy to understand, the displacement are defined as _u_ =(u,v,w) in most physics (in fact where relevant).
if you are in PDE mode you can rename the dependent variables in the main node, or better during definition
Hi your question is not easy to understand, the displacement are defined as _u_ =(u,v,w) in most physics (in fact where relevant). if you are in PDE mode you can rename the dependent variables in the main node, or better during definition -- Good luck Ivar
Posted: 1 decade ago 2011/03/10 18:15 JST
Hi Ivar,
I am in PDE's- wave equation(waeq)-2D and I have u as the dependent variable. I want u(x,y,t) and then I want to consider a pulse at one boundary. But I want the dependent variable be dispalcment in x or y direction.
How could I do that?
thank you
Hi Ivar, I am in PDE's- wave equation(waeq)-2D and I have u as the dependent variable. I want u(x,y,t) and then I want to consider a pulse at one boundary. But I want the dependent variable be dispalcment in x or y direction. How could I do that? thank you
Posted: 1 decade ago 2011/03/10 19:20 JST
make a "new model: 2D structural physics" and check the dependent variables there you have (u,v) for the displacements. This is called _u_ in bold as vector field in x,y.
When you select a time dependent /transient solver COMSOL adds the time derivatives such as ut, vt wich is to be read as d(u)/dt and d(v)/dt
Read the doc and try out a simple model to understand the default conventions of COMSOL
Hi make a "new model: 2D structural physics" and check the dependent variables there you have (u,v) for the displacements. This is called _u_ in bold as vector field in x,y. When you select a time dependent /transient solver COMSOL adds the time derivatives such as ut, vt wich is to be read as d(u)/dt and d(v)/dt Read the doc and try out a simple model to understand the default conventions of COMSOL -- Good luck Ivar
Posted: 1 decade ago 2011/03/10 19:41 JST
Ivar,
for structural mechnaic I did it easily but for PDE's it is a bit confusing. The problem I have is that I can not assign the dependent varaible u to be considered displacment in x or y in PDE. In structuaral physics easyly I can define pressure, displacment and its deriviative because dependent variable is displacment but in PDE dependent variable is u that could be everthing like pressure displacmnet ,... how to make comsol to get dependent variable (u) in comsol displacment or something else I am confused.
however thank you very much Ivar.
Ivar, for structural mechnaic I did it easily but for PDE's it is a bit confusing. The problem I have is that I can not assign the dependent varaible u to be considered displacment in x or y in PDE. In structuaral physics easyly I can define pressure, displacment and its deriviative because dependent variable is displacment but in PDE dependent variable is u that could be everthing like pressure displacmnet ,... how to make comsol to get dependent variable (u) in comsol displacment or something else I am confused. however thank you very much Ivar.
