Use my resultat in the another study (help me)
Posted 2017/08/04 4:18 GMT-4 Fluid & Heat, Computational Fluid Dynamics (CFD), Mesh Version 5.3 0 Replies
I work in the two-phase flow (Level set method - laminar flow) and I would like your help!
In my case study, I have a bubble that falls into another fluid and I would use an infinite domain but I can not because the mesh is too thin (0.01cm mesh size) and the CPU is too expensive (2 days calculation for 1s). For that I would like to know if I can take my results in the first study and put this results at the top of the same geometry to avoid the effect edge down and I make a loop like that?
I would also like to know if I can take my results in the first study and I use it in another different study (differnet geometry or physical condition or mesh ... etc)
I thank you in advance.
Hello Baraa Qaddah
