regarding ACDC module
hi ,,
i am designing a magnetic core.. if we pass current in the primary it will give some magnetic flux density value for some currents above that i should give a constant value.
how to limit the flux density above that value
for example.. i have designed my core.up to 10 A it should give magnetic flux density ..after 10A even if we increase current also it should not give any value it should saturate..
how to give and where to give that saturation value in comsol 4.0
i will be very thankful if any one give me any idea on this...
thanks in advance.
3 Replies Last Post 2011/03/12 5:37 JST
Posted: 1 decade ago 2011/03/11 19:52 JST
you need to set the material properties of your iron to link the mur to the norm of the field, normally there is the iron with or without losses that is set up like this in the material DB
Hi you need to set the material properties of your iron to link the mur to the norm of the field, normally there is the iron with or without losses that is set up like this in the material DB -- Good luck Ivar
Posted: 1 decade ago 2011/03/12 3:07 JST
hi ivar,
thanks for your response..
when i am using the same with that i am not getting my theroitical values so i defined normal cast iron with mur=2000.how to use softiron with mur =2000 to my model.i mean how to link that value to my model.
hi ivar, thanks for your response.. when i am using the same with that i am not getting my theroitical values so i defined normal cast iron with mur=2000.how to use softiron with mur =2000 to my model.i mean how to link that value to my model.
Posted: 1 decade ago 2011/03/12 5:37 JST
you should look it up in the doc, you need to enter the saturation curve, typically as an interpolated set of data in columns, then define the H B relation
normally in the default ACDC material section there should be a e an iron with saturation already set up, use that as example
Hi you should look it up in the doc, you need to enter the saturation curve, typically as an interpolated set of data in columns, then define the H B relation normally in the default ACDC material section there should be a e an iron with saturation already set up, use that as example -- Good luck Ivar
