Multi variable dependent table material property
Evthimios Karaliolios
Hi all,
I am trying to import a table containing Magnetization values for Gd, based on the temperature T (K) and the magnetic induction B (T) for a magnetocaloric refrigeration simulation. However, I cannot find a way to import such a table with Comsol understanding to interpolate it for two variables.
Does anyone know a way to do this?
Any help is much appreciated!
2 Replies Last Post 2017/08/11 1:27 JST
Jeff Hiller COMSOL Employee
Posted: 8 years ago 2017/08/10 6:06 JST
Hello Evthimios,
See the Reference Manual for COMSOL Multiphysics, version 5.3, page 282 and following.
All manuals are accessed through File > Help > Documentation.
Hello Evthimios, See the Reference Manual for COMSOL Multiphysics, version 5.3, page 282 and following. All manuals are accessed through File > Help > Documentation. Best, Jeff
Posted: 8 years ago 2017/08/11 1:27 JST
Thank you Jeff! I figured out how to import the data from Excel into Comsol. Thanks for showing me the right section in the manual, it can be quite extensive sometimes.
However, I still have the feeling that the data is not really linked with the output variables (temperature ht.T, magnetic flux density mfnc.normB) of other parts of the model I am designing. I would like to be able to use customized magnetization values based on the temperature distribution and magnetic flux density field in the system. How can I link those?
Thank a lot in advance!
Evthimios
Thank you Jeff! I figured out how to import the data from Excel into Comsol. Thanks for showing me the right section in the manual, it can be quite extensive sometimes. However, I still have the feeling that the data is not really linked with the output variables (temperature ht.T, magnetic flux density mfnc.normB) of other parts of the model I am designing. I would like to be able to use customized magnetization values based on the temperature distribution and magnetic flux density field in the system. How can I link those? Thank a lot in advance! Evthimios
