2011/04/09 3:44 JST
You need to go My Computer>Right Click>Properties>Advanced System Settings then
Environment Variables and add PRO_COMM_MSG.EXE as variable name and path of file as variable value
which is like C:\Program Files (x86)\proeWildfire 4.0\i486_nt\obj\pro_comm_msg.exe
Place it in system variable section and do a restart.
Unfortunately. I found your message while I was having the same problem. This did not help me but I hope it solves your problem..
System
Hi All,
I have installed live link for Pro-Engineer 4.0.
On the Comsol model builder right click and Livelink for Pro-Engineer. As i click on synchronize, an error report was appear:
Failed to connect to Pro/ENGINEER.
Please check the PRO_COMM_MSG_EXE environment variable is set correctly before launching COMSOL.
please tell me how to repair this failure.
thanks
regards
System
[QUOTE]
Hi All,
thanks
regards
[/QUOTE]
2013/06/27 21:41 JST
When you add Environment Variables do not add PRO_COMM_MSG.EXE but PRO_COMM_MSG_EXE this solved it for me.
9 years ago
2015/12/07 13:37 JST
hey you said " path of file as variable value
which is like C:\Program Files (x86)\proeWildfire 4.0\i486_nt\obj\pro_comm_msg.exe"
please explain how to find this variable value
9 years ago
2016/10/13 12:12 JST
hi,
have you solved this promblem at last? I have done everything as they said, but it didn't work.
Could you please tell me how do you solve it.
Thank you~~~
hi,
Thank you~~~
