2011/03/18 5:37 JST
your gap must be "closed" hence be part of the simulation, else the field/flux is not going to "jump the gap" But the material properties of this gap is not necessarily a solid, "empty" vacuum is also possible, with its RF properties, but it must be there and meshed
2012/04/21 4:30 JST
Hi Damla,
I'm trying to do the same thing as you, I was wondering if you have any success in modeling the ring resonator in comsol and/or what troubles do you found on the way.
Thanks in advance.
Felipe
Hi Damla,
Thanks in advance.
Felipe
2012/04/23 21:42 JST
Hi Felipe and Damla,
I'm also studying the effect of coupling waveguides to a ring resonator. May we share the result of your simulation and compare the notes if you able to get the results.
Please do email me at zuldrac@yahoo.com
2012/11/02 7:04 JST
Hi Felipe, Damia and Zulhisham,
I'm working on ring resonator now and I would like to do a simulation with an axial symmetric geometry to find the ring modes.
But I didn't see any confined mode. Have you ever tried to do this kind of simulation?
Thank you
Sara
Thank you
Sara
2013/03/12 16:50 JST
Hi Sara,
I am doing the same thing as you, but I have no idea how to use the axial symmetric geometry to analysis the mode in the cross section of a ring resonator which is coupling with a slab waveguide. Have you manage to see mode there? Could you share some setting tips?
My email is ying,ma@tu-harburg.de
Thanks alooooot :)
Ying
Hi Sara,
Thanks alooooot :)
Ying
