2011/03/21 3:48 GMT-4
I believe you should be able to enter your values into an interpolation function and then call this function in your variable definition.
there are already a few discussions about such approaches on the Forum
2011/03/21 4:13 GMT-4
Thanks for the prompt reply, yes i did as per your suggestion and getting some error,i should look in to more and have attached the document ,i feed the tabular format in functions box and called it in Global global expressions
Thanks for the advice
Regards
Arun Kannaiyan
Regards
Arun Kannaiyan
2011/03/21 4:18 GMT-4
one more thing, you must check how you pass the variables to the function, either explicitly with a "F1(x,y)" or implicitly just "F1". that depends on the settings you have chosen, and I cannot fully remember how it was in 3.5 ;)
The implicit way is the most common in COMSOL, even so common that you forget it's there (and when not) and you generate subtle errors like that
2011/03/21 7:47 GMT-4
I feed the tabular format in functions dialog box and called the functions it in Global global expressions using the variables to the function, implicitly "F1".But iam getting errors,whether i can call the functions in global expression dialog box.
Thanks in advance
Regards
Arun Kannaiyan
Thanks in advance
Regards
Arun Kannaiyan
2011/03/22 7:52 GMT-4
I feed the tabular format in functions dialog box and called the functions it in Global global expressions using the variables to the function, implicitly "F1". i cant able to call the functions in global expression dialog box.
2011/03/22 7:53 GMT-4
I feed the tabular format in functions dialog box and called the functions it in Global global expressions using the variables to the function, implicitly "F1". i cant able to call the functions in global expression dialog box. please help me out from this problem
Thanks in advance
Regards
Arun Kannaiyan
Thanks in advance
Regards
Arun Kannaiyan
