Randomized Hexagon Using Model Methods ?
Hi, friends
There is a simple code for generating randomized spheres using model methods:
//************************************************ model.component("comp1").geom("geom1").create("sph"+ind, "Sphere"); model.component("comp1").geom("geom1").feature("sph"+ind).set("r", hr); model.component("comp1").geom("geom1").feature("sph"+ind).set("pos", new double[]{hx, hy, hz}); //************************************************* Ref: https://www.comsol.asia/blogs/how-to-create-a-randomized-geometry-using-model-methods/
In a 2D model, I simply modified "Sphere" to "Circle", but what about regular hexagon ?
3 Replies Last Post 2017/10/18 6:27 JST
Jeff Hiller COMSOL Employee
Posted: 8 years ago 2017/10/18 3:17 JST
Updated: 8 years ago 2017/10/18 3:18 JST
The simplest was to create a regular hexagon is to use the Polygon tool and to take advantage of the "range" operator and the "cos" and "sin" functions, as shown in the attached file, which also shows the corresponding model method. From there you just need to add the randomness (i.e. scaling, rotation, center location).
Jeff Hiller
The simplest was to create a regular hexagon is to use the Polygon tool and to take advantage of the "range" operator and the "cos" and "sin" functions, as shown in the attached file, which also shows the corresponding model method. From there you just need to add the randomness (i.e. scaling, rotation, center location). Best, Jeff
Posted: 8 years ago 2017/10/18 5:21 JST
Dear Jeff,
Thanks a lot for your quick reply. I successfully created a polygon (pol1) and scaled it (sca1), But the code:
** model.component("comp1").geom("geom1").create("pol"+ind, "sca1") ** leads to error. How can I add randomness in center location ?
Dear Jeff, Thanks a lot for your quick reply. I successfully created a polygon (pol1) and scaled it (sca1), But the code: ** model.component("comp1").geom("geom1").create("pol"+ind, "sca1") ** leads to error. How can I add randomness in center location ?
Posted: 8 years ago 2017/10/18 6:27 JST
You can change the location of the center of the polygon by modifying the expressions used for the x and y coordinates of its vertices.
It should be pretty straightforward but if you should need further assistance, please contact COMSOL's technical support team at support@comsol.com .
Jeff Hiller
You can change the location of the center of the polygon by modifying the expressions used for the x and y coordinates of its vertices. It should be pretty straightforward but if you should need further assistance, please contact COMSOL's technical support team at support@comsol.com . Best regards, Jeff
