Surface Equilibrium Reaction in 2Daxi Transport of Diluted Species
I'm following the protein adsorption protocol, but modifying it for my axisymmetric model of surface protein adsorption in a static medium. For some reason, the Surface Equilibrium Reaction under Transport of Diluted Species is grayed out. I looked under the Physics menu and Surface Equilibrium Reaction cannot be added manually, which seems like this wasn't supposed to function this way. However, Generate Space-Dependent Model under Reaction Engineering does seem to be able to create it.
I'm a little stuck, is there a way to initialize it that I'm not getting or is there a way of bypassing the problem entirely?
1 Reply Last Post 2017/11/01 22:25 JST
Posted: 8 years ago 2017/11/01 22:25 JST
If I started a new model, I can select both Transport of Diluted Species and Surface Reaction physics. Also, below tds node, there is electrode surface coupling.
BR Lasse
Hi If I started a new model, I can select both Transport of Diluted Species and Surface Reaction physics. Also, below tds node, there is electrode surface coupling. BR Lasse
