Store solutions and use them in second physics
Posted 2017/10/28 22:58 JST Parameters, Variables, & Functions, Results & Visualization, Studies & Solvers 0 Replies
Hello all.
I want to store the solution from one physics module and insert them (with interpolation maybe) in the second physics module of my program. Should I use the combine solutions?
I think I should run a parametric sweep for my first study and then store the calculated variable. Then how do I insert the variable in my second study? with interpolation maybe?
More specifically I want to calculate the deposited power(variable name=comp1.gop.wall1.bscr1.Qp) from a ray optics module for a time range(8,15[min],17) with parametric sweep for time. Then I think to insert these variables to a Heat Transfer module and use a Heat Flux and an interpolation function to insert the variables above. Is there a way to do this?
Thank you in advance for your help.
Best rigards, Panos Kagioulis
Hello Panagiotis Kagioulis
