attenuation
How could I define attenuation(dB/meter) in wave propagation in PDE module of comsol ?
cheers
3 Replies Last Post 2011/03/25 20:03 JST
Posted: 1 decade ago 2011/03/24 16:04 JST
what do you mean ?
to plot
20*log10(myVar)
or to find the expression of myVar ?
Hi what do you mean ? to plot 20*log10(myVar) or to find the expression of myVar ? -- Good luck Ivar
Posted: 1 decade ago 2011/03/25 17:30 JST
Thank you for your reply? I mean how could I enter attenuation in system? what is myvar and how could I obtain it?
cheers,
Hi, Thank you for your reply? I mean how could I enter attenuation in system? what is myvar and how could I obtain it? cheers,
Posted: 1 decade ago 2011/03/25 20:03 JST
"myVar" is just a quick name I use to represent any "user" variable. In your case you must then define
myVar = attenuation.
For me attenuation is model dependent, ie. could be the ratio of the integral of the input field to the output field, or the ratio of the values at two locations ...
Hi "myVar" is just a quick name I use to represent any "user" variable. In your case you must then define myVar = attenuation. For me attenuation is model dependent, ie. could be the ratio of the integral of the input field to the output field, or the ratio of the values at two locations ... -- Good luck Ivar
