Henrik Sönnerlind
COMSOL Employee
8 years ago
2017/11/10 3:40 JST
If you stretch and release an (hyper)elastic material you follow the same path. If you move to compression, then the tensile test may not be sufficient.
A triaxial compression test is meningless because of the incompressibility, while a unixial compressive test is important. You can compress rubber a lot along one axis, it only expands in the two other directions to maintain its volume.
I think the discussion in this blog post might be of interest:
https://www.comsol.com/blogs/obtaining-material-data-for-structural-mechanics-from-measurements/
Henrik
Henrik Sönnerlind
COMSOL
Henrik
8 years ago
2017/11/10 4:18 JST
Dear Henrik
Thank you very much for clarification..
In fact, I want to stretch a rubber from both ends to achieve a specific strain, then Im going to pattern or attach a ribbon on the top of the stretched rubber. Finally, Im going to release the rubber to its original size. I dont know how to implement this mechanism. Actually I cant understand how to join an unstrained object ( in my case, the ribbon) to a prestrained object( rubber) Could you please help me?
Dear Henrik
7 years ago
2018/01/16 22:05 JST
Hello Richard Anderson,
Have you solved the problem of stretching the rubber from the ends. I also want to do the same, but with the fixed constraints it is not possible and I don't want to fix the constrains. I am using PDMS as stretchable material and want to stretch from both the ends.
Asad Nauman
Asad Nauman
