Meshing parasolid imported structure
Hi.
I've imported a parasolid strucure to comsol 4.1 by following the user manual instructions.
My structure is a multi-wire birdcage with a metal support at both ends. I've not changed the default meshing configuration. Is there any documentation about the best way to mesh such a structures?
Any example?
Javier
1 Reply Last Post 2011/03/26 17:09 JST
Posted: 1 decade ago 2011/03/26 17:09 JST
try the default meshing, mostly it's OK. If you have a structure with multiple loops (tores) the mesher might nhave some issues. Then often its better to split the volumes into smaller items, you get more domains to handle and a few interiour boundaries extra, but that often helps the mesher. And you can taylor the mesh locally at will in a much easier way
Hi try the default meshing, mostly it's OK. If you have a structure with multiple loops (tores) the mesher might nhave some issues. Then often its better to split the volumes into smaller items, you get more domains to handle and a few interiour boundaries extra, but that often helps the mesher. And you can taylor the mesh locally at will in a much easier way -- Good luck Ivar
