Nirmal Paudel
Tribhuvan University/Electrical Engineering
8 years ago
2017/12/12 23:00 JST
Updated:
8 years ago
Hi Prasanna,
I would suggest you to go through the following two blog posts to implement this moving mesh to model the moving Iron. This is very similar to the plunger example here:
https://www.comsol.com/blogs/part-1-how-to-model-a-linear-electromagnetic-plunger/
https://www.comsol.com/blogs/part-2-model-a-linear-electromagnetic-plunger-with-a-blocker/
NOTE: The links for the associated model files are there in the blog post itself.
Best Regards,
Nirmal
Hi Prasanna,
1. https://www.comsol.com/blogs/part-1-how-to-model-a-linear-electromagnetic-plunger/
2. https://www.comsol.com/blogs/part-2-model-a-linear-electromagnetic-plunger-with-a-blocker/
Best Regards,
Nirmal
8 years ago
2017/12/13 17:26 JST
Dear Nirmal,
Thanks for your advice. It was helpful. I will try it and let you know the feedback.
Prasanna G
Dear Nirmal,
8 years ago
2017/12/26 17:21 JST
I have tried the model with base model as electromagnetic plunger. But, I am getting the same error stating that mf.normB is undefined variable. In eletromagnetic plunger model lorentz force is used. In my model, I need magnetic force to be coupled in order to lift the sample. Can somebody please advice?
Added to it, I am also trying to implement Heat Transfer to the sample after the magnetic force is exerted on a sample. I find difficulty in implementing the Heat Transfer (ht) as we need to implement the susceptibility with variation in temperature to the sample (values imported in .txt format and can be found at interpolation table in model).
Can someone please advise me the error in this model?
I have attached the model for your reference.
Prasanna G
