Laminar flow problem does not converge for most boundary conditions
Posted 2017/12/11 13:51 GMT-5 Fluid & Heat, Computational Fluid Dynamics (CFD), Geometry Version 5.3 0 Replies
HI,
I have set up a 3D laminar flow problem in a rectangular geometry with an inlet and outlet. The problem presents in reality a fluid exchange problem: a box of fluid is connected to a pump, which introduces another species of fluid from the inlet while the fluid in the box is expelled through the outlet.
I tried a variety of boundary conditions for the inlet and outlet but only few of them result in a converging simulation. Ideally, I would like both inlet and outlet to have laminar inflow/outflow=1e-6 m^3/s; however, this condition does not give a converged solution. I know from your forum that specifying both inlet and outlet boundaries to be velocity/flow rate may cause problems to convergence, so I also tried specifying velocity/inflow at the inlet and a constant pressure at the outlet. However, this works only if pressure=0Pa, which is far from ideal for my system.
Can someone suggest any reason that possibly causes the convergence problem, and what would be the solutions?
Thanks.
Hello Nicole Luk
