Novice Question - Partitioning Domains in 2-D
Hello all,
I'm working on a Comsol design of a device through which fluid will flow. I used SolidWorks to design the device, and imported the relevant face as a .DXF to obtain the 2-dimensional cross section that I want to model flow through. The overall design is thus: Design
I'd like to keep this domain: Domain to be kept
And subtract these domains: Domains to be subtracted
I've used the "partition domains" function to identify/highlight the relevant portions, but I seem to be unable to use the "difference" tool to delete the domains I want gone. I need to use the edges of the to-be-subtracted domains as walls, and the vertical lines connecting the innermost rings as the outlets.
Any help is greatly appreciated, please let me know if more clarification is needed.
2 Replies Last Post 2017/12/17 5:05 JST
Posted: 8 years ago 2017/12/16 5:09 JST
Skylar,
You can use Conversion/Split option to partition domains and then delete/substract domains, as illustrated in the attached dummy model.
Sergei
Skylar, You can use Conversion/Split option to partition domains and then delete/substract domains, as illustrated in the attached dummy model. Regards, Sergei
Posted: 8 years ago 2017/12/17 5:05 JST
Hello Sergei,
Thank you for your reply. I seem to be unable to build the object, and am also unable to toggle any of the input domain selections to 'on'. I notice, though, that when the switch is off, I am able to select different sub-domains - this is also the case in my model, but I lose this capability when I try to switch it to 'on'.
I believe the reason I am unable to build the object and test out the split/delete functions is because I don't have the X-Section.mphbin that Comsol is trying to import, is this correct?
Switch Off Switch On X-Section
Hello Sergei, Thank you for your reply. I seem to be unable to build the object, and am also unable to toggle any of the input domain selections to 'on'. I notice, though, that when the switch is off, I am able to select different sub-domains - this is also the case in my model, but I lose this capability when I try to switch it to 'on'. I believe the reason I am unable to build the object and test out the split/delete functions is because I don't have the X-Section.mphbin that Comsol is trying to import, is this correct? ![Switch Off](https://i.imgur.com/VKfRZ3v.png) ![Switch On](https://i.imgur.com/dVfDwwb.png) ![X-Section](https://i.imgur.com/EGV50D3.png)
