exponential function error
Posted 2011/03/31 21:09 JST Version 4.0a 11 Replies
In global definition>funtions
I defined the function : exp(-1/(T-Tg)) , T was arguments.
At T=Tg, the exponential value should be zero but it was infinity.
can anybody help??
If you approach Tg from the left, i.e. is T is almost Tg but slightly less, then the function goes to +infinity (just try to solve the limit, the exponent wil go to +infinity), if you approach Tg from the right then it goes to zero (the exponent goes to -infinity) at the limit never really reaching zero.
Hello~
can anybody help??
I understood your comment but, how can i treat that function to be zero?
Is there any limit operator in comsol?
but the answer was infinity...
The value becomes 0 or infinity depending on from which side you approach it. You are probably plotting a range that includes values on both sides of Tg.
Plotting exp(-1/(5-x)), for example, from 0 to 5, shows that the value approaches 0 "from the left." Plotting this function from 0 to 10, for example, means that you pass the singularity at 5, and an infinite value (or rather numerically very large number) makes the plot appear irregular.
Magnus Ringh, COMSOL
you might consider a step-by-step definition to avoid the singularity:
f(T) = 0 for abs(T-Tg) < some very small value
Regards
Edgar
Nagi Elabbasi
Veryst Engineering
I've solved that problem.
a usefull "epsilon" or small value is the paameter (internal to COMSOL of "eps", smallest step value you might distinguish from "1" in the used binary numerical representation
Plotting your exponential function in exp(-1/(5-x)), for example, from 0 to 5, shows that the value approaches 0 "from the left." Plotting this function from 0 to 10 put in to values let - x=0,1,2,3,,,,and shown for more solving equation u can got help with the site here's the link
math.tutorvista.com/calculus/graphing-exponential-functions.html
So, our Pre-calc teacher thinks we are geniouses since we are in a pre calc class-__- so she never really explains us stuff.and doesnt teach the way book teaches.but im scared to come up to her because she's a freaking Gorgon and we got like 14 people left in this class cause they all switched out...anyways.. So here's the problem i cant figure out. You gotta use this exponential formula: y=Pe^rt (to the 'rt' power) .
The word problem: Radium-221 has a half-life of 30 sec. How long will it take for 95% of a sample to decay?
Could anyone please just explain what to put where? would you convert 95% into decimal and use is as P?
Thank you!!
NICK
looks like you have to find a value for the radium decay constant...
I wouldn't convert 95% into decimals and use it as P...
isolate t...
