Hello Yang Yulong
                                2014/04/01 10:35 GMT-4
                                                    The problem is related to a Windows user name that contains national characters.
In COMSOL, if the the error node under the solver node is inspected, a message similar to (if the user is named José) will be visible:
Cannot open native file.
- Detail:
c:\Users\Jos?\.comsol\v42\recoveries\MPHRecovery5657date_Nov_1_2010_2-34_PM.mph\solution1.mphbin
Two alternative alternative workarounds can be used:
Specify a recovery directory without special national characters: Change the target of the COMSOL shortcut to e.g., [path]\comsol.exe -recoverydir c:\COMSOLRecoveries where [path] is the name of the COMSOL installation directory. To change the target, right-click the COMSOL icon and select Properties. In the Target edit field, add -recoverydir c:\COMSOLRecoveries to the comsol command like shown above.
A less recommended workaround is to turn off recovery files: Select the menu Options->Preferences, go to Save, clear the checkbox "Save recovery file". You can also add the -autosave off switch to the comsol start command (see point 1 above for instructions), by changing the shortcut target as outlined above. This latter option must be used if you run client/server and want to turn off recovery files.
The underlying problem is that COMSOL fails to save files in the home directory if the user name has national characters, for example José. The recovery files are used by COMSOL to save intermediate results so that if COMSOL crashes during a computation, the computation can be resumed from the last stored point. COMSOL is working on a fix for this character problem. This problem is much less common in version 4.2 than 4.1, so it is a good idea to upgrade to latest release if you haven't already.
- Detail:
