Magnus Ringh
COMSOL Employee
8 years ago
2018/01/11 16:34 JST
That's because the model uses a physics-controlled mesh (see the Sequence type list in the Mesh node's Settings window). A physics-controlled mesh for electromagnetic waves sets the mesh size to resolve the wavelength. For the frequency-domain analysis in this model, the frequency is set to 10 GHz, which corresponds to a wavelength that far exceeds the dimension of the geometry in the model (10x10 micrometers). You can get a fine mesh by switching to a user-defined mesh or by increasing the frequency by several orders of magnitude.
Magnus Ringh, COMSOL
That's because the model uses a physics-controlled mesh (see the **Sequence type** list in the **Mesh** node's **Settings** window). A physics-controlled mesh for electromagnetic waves sets the mesh size to resolve the wavelength. For the frequency-domain analysis in this model, the frequency is set to 10 GHz, which corresponds to a wavelength that far exceeds the dimension of the geometry in the model (10x10 micrometers). You can get a fine mesh by switching to a user-defined mesh or by increasing the frequency by several orders of magnitude.
8 years ago
2018/01/12 2:46 JST
Hi, Thanks alot for your quick reply. Its clear now :)
