Need help: COMSOL Optimizer under different components
Posted 2018/01/11 14:53 GMT-5 Chemical, Chemical Reaction Engineering, Optimization Version 5.2a 0 Replies
I am having trouble using the COMSOL optimization module to solve for a kinetic parameter in a converged model while fitting measured data.
I have a converged model with a 1D fluid phase component and a 2D particle/porous component set up. I am trying to optimize a parameter under the particle component to fit experimental data measured under the fluid phase component.
I set up the optimizer least square objectives with attached data csv file under the fluid phase component and the global control variable for the parameter desired to be optimized. I run into an error message **“Undefined function at the initial point. Returned solution is not converged”. **
Has anyone done anything similar to this? Am I missing something setting it up or attaching the data?
Gary
Hello Gary Xing
