basalt melting in a Microwave cavity
Hello I am trying to simulate a 3Dsimulation of melting a 30x30x30mm^3 basalt rock in a TE mode microve cavity. Using multiphysics of RF microwave and Heat transfer in solids. I am taking in to consideration convective heat transfer and radiation from the borders of the rock to the air in the cavity. I want to consider the melting of the material so i tryed two ways. * First i defined peicewzie properties for the basalt parameters. before melting temperature and after. I enqaunterd two problems. The first was a convergion problem, when the temperature reaches the melting temperature i see in the segragated solver that the error reaches infinit values, the second is that in the results i see very high temperatures. * I simulated phase change, using another material for the temperature above melting temperature defining a peicewize propetry for each material. The simulation chonverges but the results are not physical. I have tryed to find answers in the forum but didnt see a referense for a 3D simulation. I am strugelling with this problem for several months now. can someone please help me i would very appreciate it. yoav
3 Replies Last Post 2018/01/28 3:54 JST
Posted: 7 years ago 2018/01/27 2:08 JST
Hi yoav shoshani To avoid unreasonable temperature use fitting in sharp corner.
Posted: 7 years ago 2018/01/27 3:13 JST
I mean fillet
I mean fillet
Posted: 7 years ago 2018/01/28 3:54 JST
Thank you Mamad I have used filleting in my simluation. any other ideas?
Yoav
Thank you Mamad I have used filleting in my simluation. any other ideas? Yoav
