Batch command
Hi all, this may look as a very basic question but it is taking so much of my time. i am trying to run comsol in bath mode via command line whcih is supposed to be super simple. I keep getting errors on that. this is the command: comsolbatch -inputfile filename.mph -outputfile filename_solved.mph
any hints? your help is much appreciated.
Regards, Asal Bidarmaghz
6 Replies Last Post 2018/02/02 18:42 JST
Jeff Hiller COMSOL Employee
Posted: 8 years ago 2018/02/02 1:04 JST
Hello Asal,
This blog may help:
https://www.comsol.com/blogs/how-to-run-simulations-in-batch-mode-from-the-command-line/
Jeff Hiller
Hello Asal, This blog may help: https://www.comsol.com/blogs/how-to-run-simulations-in-batch-mode-from-the-command-line/ Best regards, Jeff
Posted: 8 years ago 2018/02/02 1:21 JST
Hi Jeff, thank you. this is exactly the blog I followed for the command line.
still get the error.
Regards, Asal
Hi Jeff, thank you. this is exactly the blog I followed for the command line. still get the error. Regards, Asal
Posted: 8 years ago 2018/02/02 1:40 JST
Without knowing anything about your license, environment or error message, it's hard to tell you more. An educated guess would be that you may not have added the path to the COMSOL executable to your PATH. I would recommend you contact our support team and provide specific details about the error you are getting.
Jeff Hiller
Without knowing anything about your license, environment or error message, it's hard to tell you more. An educated guess would be that you may not have added the path to the COMSOL executable to your PATH. I would recommend you contact our support team and provide specific details about the error you are getting. Jeff
Posted: 8 years ago 2018/02/02 1:44 JST
I have contacted them and thank you. in the meantime, I suspect this is it. How should I add the path?
Many thanks, Regards, Asal
I have contacted them and thank you. in the meantime, I suspect this is it. How should I add the path? Many thanks, Regards, Asal
Posted: 8 years ago 2018/02/02 1:50 JST
It depends on your OS. For Windows, see, e.g., https://www.howtogeek.com/118594/how-to-edit-your-system-path-for-easy-command-line-access/ .
Jeff Hiller
It depends on your OS. For Windows, see, e.g., https://www.howtogeek.com/118594/how-to-edit-your-system-path-for-easy-command-line-access/ . Jeff
Posted: 8 years ago 2018/02/02 18:42 JST
Perfect. Many thanks. it worked.
Regards, Asal
Perfect. Many thanks. it worked. Regards, Asal
