Error with command mphgeom(x,y)
Posted 2011/04/06 9:55 GMT-4 Interfacing Version 4.0a 0 Replies
Using Matlab R2010a, I tryed to plot an imported, yet simple, Bézier polygone or serie of points, without sucess.
Matlab is returning fatal error. The difficulties might be due to a non-solid geometry.
Someone already experienced ?
Try the following: simply four points. You should have to change model path.
_____________________________
function out = model
import com.comsol.model.*
import com.comsol.model.util.*
model = ModelUtil.create('Model');
model.modelPath('C:\Users\carg0029\Desktop');
model.modelNode.create('mod1');
model.geom.create('geom1', 3);
model.mesh.create('mesh1', 'geom1');
model.geom('geom1').run;
model.mesh.remove('mesh1');
model.geom('geom1').feature.create('pt1', 'Point');
model.geom('geom1').runAll;
model.geom('geom1').run('pt1');
model.geom('geom1').feature.create('pt2', 'Point');
model.geom('geom1').feature('pt2').setIndex('p', '1', 0);
model.geom('geom1').run('pt2');
model.geom('geom1').feature.create('pt3', 'Point');
model.geom('geom1').feature('pt3').setIndex('p', '1', 1);
model.geom('geom1').feature('pt3').setIndex('p', '1', 0);
model.geom('geom1').run('pt3');
model.geom('geom1').feature.create('pt4', 'Point');
model.geom('geom1').feature('pt4').setIndex('p', '1', 1);
model.geom('geom1').run('pt4');
mphgeom(model,'geom1')
out = model;
Hello Gabriel Caron
