beam - 3D solid connection
Hi, I have modelled rail as beam and sleepers as 3D solid and I need to connect rail to sleepers. there is no option available in comsol to connect beam with 3D solid. I need any other alternative.
Regards Varsha
2 Replies Last Post 2018/02/26 15:33 JST
Posted: 8 years ago 2018/02/23 15:45 JST
Updated: 8 years ago 2018/02/23 15:46 JST
Hi Varsha,
If you are running the latest version (5.3a) you can use the Solid-Beam Connection multiphysics coupling.
https://www.comsol.com/release/5.3a/structural-mechanics-module
If not, you probably need to use an extrusion coupling operator, and then a Prescribed Displacement node in the Solid Mechanics interface in which the displacements are set to match those in the beam.
Henrik
Henrik Sönnerlind
COMSOL
Hi Varsha, If you are running the latest version (5.3a) you can use the Solid-Beam Connection multiphysics coupling. If not, you probably need to use an extrusion coupling operator, and then a Prescribed Displacement node in the Solid Mechanics interface in which the displacements are set to match those in the beam. Regards, Henrik
Posted: 8 years ago 2018/02/26 15:33 JST
Hi Henrik,
Thank you for your help
Regards Varsha
Hi Henrik, Thank you for your help Regards Varsha
