Jeff Hiller
        COMSOL Employee
                                8 years ago
                                2018/03/02 8:33 GMT-5
                        Updated:
                                8 years ago
                                2018/03/02 8:34 GMT-5
                                                    Did you remember to pass time as an argument to the function when you call it?
wv1(t)
    Jeff Hiller
wv1(t)
                                8 years ago
                                2018/03/02 9:46 GMT-5
                                                    Hello Jeff!
Thank you for your prompt answer.
I changed a bit my geometry and integrated a Coil to generate the magnetic field. (I got rid of the magnetic field replacing the Magnetic Insulation Boundary).
I had the same trouble when I write wv1 in the Coil current: COMSOL did not know this variable :(
I've tried passing the time as argument and writing wv1(t) in the Coil current but still got into trouble: COMSOL said there is an issue with the Units :(
Then I created an analytic function such as: an1(t) = 0 + wv1(t)
And now I can associate it with the coil current!!! COMSOL accepts it as the Coil current :)
I will go further and try to apply it on an Magnetic Isolation boundary replaced by a Magnetic Field from an1(t).
David
                            Hello Jeff!
David
                                8 years ago
                                2018/03/02 12:06 GMT-5
                                                    Hello Jeff!
I tried to apply the analytic function an1(t) on the Magnetic Isolation replaced by "Magnetic field" and it works! I wrote an1(t) in the Hx coordinates.
Strangely it does not work with the waveform function wv1(t).
David
                            Hello Jeff!
David
