Eigenfrequency analysis with load
Posted 2011/04/11 10:39 GMT-4 Studies & Solvers, Structural Mechanics Version 3.5a 2 Replies
Hi to all,
I am new in Comsol ( Comsol 3.5a ) and I am facing problem to find out eigenmodes in a simple structure WITH A LOAD APPLIED on a boundary. It will be very helpful if someone can give some advice.
I am trying to find out eigenfrequencies of Poly-Si surface(2D) in vacuum with a load applied , so to get acquainted with that kind of problem I started solving a very simple problem , I drew a rectangle of poly-Si ( width = 500e-6 , height= 5e-6 ) , I fixed the upper and lower boundary and after setting a load on one of free boundary I solved the model.
I get as result same eigenfrequencies I obtain when I solve the model without load.
I read others discussions and I understood it's not the right way, so I tried performing a static analysis , where I apply load , creating a moving mesh ( with all subdomain settings ... ) and then performing a eigenfrequency analysis on the deformed mesh ( after creating geometry from mesh..) .
When I solve results change but not as I expected, so I would like to know if , this time, it's the right way.
Thanks in advance for the answer.
Kind regards
Alessandro
Kind regards
Alessandro
2 Replies Last Post 2011/04/11 14:48 GMT-4
