Inverted Mesh problem
Posted 2011/04/11 16:53 GMT-4 1 Reply
I designed MEMS Pillar which is as vertical shape of MEMS cantilever with COMSOL 3.5a version. The design is very similar to sample cantilever that is offered from COMSOL. I used Silicon for the beam instead of Polysilicon with Aluminum above Silicon. I followed the exact tutorial and got a problem with "Inverted Mesh". The error is as follow:
Error: 7248
Undefined value found.
Detail:
Exception:
com.femlab.jni.FlNativeException: Undefined value found Solvermodel
Stack trace:
at solvermodel.cpp, row 1837, (Undefined value found in the equation residual vector.
There are 27 degrees of freedom giving NaN/Inf in the vector for the variable u
at coordinates: (2e-006,0.00032625), (2e-006,0.000328125), (2e-006,0.00033), (2e-006,0.000331875), (2e-006,0.00033375), ...
There are 27 degrees of freedom giving NaN/Inf in the vector for the variable v
at com.femlab.solver.FlSolver.femStatic(Native Method)
at com.femlab.solver.FemStatic.run(Unknown Source)
at com.femlab.server.FlRunner.run(Unknown Source)
at com.femlab.util.i.run(Unknown Source)
at com.femlab.util.aa.run(Unknown Source)
Progress - Solve Problem
Warning: Inverted mesh element near coordinates (0, 0)
Please simulate the design after download the attached file below and let me know where I should fix the model.
Thank you for your consideration.
Sincerely,
Doyoung Kim
Error: 7248
Detail:
Exception:
Stack trace:
Sincerely,
Doyoung Kim
1 Reply Last Post 2011/04/12 1:41 GMT-4
