2011/04/15 0:30 JST
it is unclear what actually your question is. Are you asking how to realize the function?
Cheers
Edgar
Cheers
Edgar
2011/04/15 3:55 JST
if so, you might write (50+350*pulse1(t)) where pulse1() is a pulse function you can "Define" higher up
2011/04/15 16:42 JST
Dear all,
Thank you for your quickly answers!
@ Edgar: I'm sorry to be not clear. :o) For answer to your question, I think to realise a rectangular function like this:
Lower limit = 0s
Upper limit = 1,1s
Size of transition zone = 0,05s
@ Ivar: I might probably change your "pulse1" by my "rect1", isn't it?
In my global definitions, I have some parameters.
Id = 50 A
Icc = 350 A
I try to do this: (Id+Icc*rect1(t)) but it's write in orange.
I write this formula in the variable table in the global definitions menu. Is it correct?
So after that, should I use a "stationary" study or anything else?
Tks
Nicolas
Dear all,
Lower limit = 0s
Upper limit = 1,1s
Id = 50 A
Icc = 350 A
Tks
Nicolas
2011/04/16 15:40 JST
you are right (I'm not always in fromt ofCOMSOL ;) it's the "rect()" operator
for the orange, it comes from an "Unit" issue, functions should be called in "unitless format" that is you must use:
rect(t[1/s])
to have t transformed to seconds but without units (by default it has [s] so multiplying it by [1/s] gives [1]
rect(t[1/s])
