Hello Xin Jin
2009/12/26 10:43 GMT-5
OOps double posting
Sorry
OOps double posting
Sorry
Hello ,
pretty new to comsol,
i get the error 6194 in a context i dont understand..(seethe full error message below)
as you will see I use the operator abs before a square root operator [ with an extra non necessary parenthesis I added in the process] but I get tthe power of negative error...
If I remove the square root the problem disappear so it is clearly aassociated with it..
and the term under the square root is abs( expression). exactely as recommended in comsol manual...
any idea on what is going on?
Thanks in advance
JF
Exception:
com.femlab.jni.FlNativeException: Failed to evaluate expression
- Expression: d(d(((-px*test(px)-(Llamf+Lturbf)*test(p))-(pt*test(p)))*(dvol_ale),{test@5}),x)
Failed to evaluate symbolic derivative variable
- Variable: Lturbf@VDN$x
- Defined as: ((1/wf)*(((2*u1d)*(((-(dflc2hs((x_fluid_front-x),(0.0010000000000000000208*x_fluid_front))/(0.0010000000000000000208*x_fluid_front)))*u)))*((abs((eps_frac/wf))^0.5)*(0.10000000000000000555*rhof))))
Power of negative
- Function: ^
Stack trace:
at evaltree.cpp, row 866, ()
at evalnodes.cpp, row 1082, ()
at evalfun_binary.cpp, row 1184, ()
at com.femlab.solver.FlSolver.femTime(Native Method)
at com.femlab.solver.FemTime.run(Unknown Source)
at com.femlab.server.FlRunner.run(Unknown Source)
at com.femlab.util.i.run(Unknown Source)
at com.femlab.util.aa.run(Unknown Source)
Hello ,
Thanks in advance
JF
Exception:
Power of negative
- Function: ^
Stack trace:
